My spare tire well fiberglass install is finished, pics!
MyEarsHurt
918
Well I finally got sick of my regular old 3/4 inch mdf enclosure taking over my trunk, and I decided to do something about it. Over the course of the last week, I have been working on my custom fiberglass spare tire well enclosure. I hope you enjoy checking out the pics. First off let me warn you, this is my first fiberglass enclosure, so granted its not perfect but I will explain how I did it anyway, just incase anyone wanted to know.
I lined the spare tire well with aluminum foil and held it in place with electrical tape.
I put one layer of fiberglass resin and mat in my trunk. I only did one layer in the trunk, and the rest I did in the backyard because fiberglass smells so bad, its ridiculous.
For the top of the "box" I used the piece of fiberboard that was originally over the spare tire. I put about 7 or 8 layers of fiberglass over the whole thing.
Then I took a piece of 3/4 inch mdf and made a cut-out of where the sub would sit. I had to use 3/4 inch mdf because otherwise the sub wouldn’t fit because it was too deep.
By far the most frustrating part of this installation was trying to get the enclosure to fit in the trunk perfectly. It didn’t, It sticks out like 1 inch, but with the carpet on you can hardly tell. In order to get it down in the spare tire well, I had to practically jump on top of it, not a simple task. There was also I lot of sanding involved... Once it was in I drilled holes for the wiring, and carpeted the whole thing with some carpet I picked up from home depot, and I also used a can of headliner adhesive from Murray’s auto parts store to hold the carpet down.
Hope you enjoyed looking at the pics! The whole thing took me a total of 4 days, and the cost of supplies were as follows:
Fiberglass resin: $40 at home depot
Fiberglass mat: $30 at home depot (7 packs)
Cheap paintbrushes: $2 at dollar store
Gloves (you need dozens of pairs, fiberglass does not come off of skin easily) $5 at home depot
Mask (a must) $5 at home depot
Hey, looks like you did a great job, first time or not!
If the glass is thick enough at the edges, you might be able to do a bit of sanding to smooth that transition a little bit. It might help smooth out that edge under the carpet a bit.
looks pretty tight dude, cheap but doesnt look cheap and thats always good the only things i could see bad about that is that now you cant use your trunk, and if you ever wanted more subs youve already got on in the dead center of the trunk? :shrug:
It sounds good, maybe its my imagination, but it seems boomier than before, of course, it is almost 1 cubic foot bigger than my previous enclosure. So maybe its not my imagination...
How much resin did you end up using? I started mine like 2 months ago and used a gallon of resin so far, and need another gallon.
I also have to deal with my battery box in the way and the roll cage.....not fun!!
I think I ended up using 2 gallons of resin total, well almost two gallons. That stuff is the expensive part too. But I have had this setup for like a month now and I couldnt be happier with it, it opened up a lot of room.
Very nice work :nice:
Thanks for providing the write-up and pictures too if I do a install I'll follow your work.
