My steering column is loose.... how to fix?
Cutter1024
118
Ephrata, PA
Since i bought my 88GT my whole steering column is loose/has play. Left/right and up/down. Its not just the wheel, its the whole column. So my question is... are there screws that could have came loose? Or is there somewhere to tighten it up? I took off the plastic surrounding the column, and wiggled the column, and couldnt really see where it could be tightened. Any ideas? Or do I need a new column?
Thanks
  • Sponsors(?)
Mustang5L5
A little massaging and it went right in
Mod Dude
Feb 18, 2001
32,297
8,483
224
Massachusetts
Remove bottom trim on dash, look for four bolts holding the column to the dash fram and tighten if necessary
Cutter1024
118
Ephrata, PA
Easy fix. Took off the plastic, took off the turn signal stem and there were the bolts. They were loose, so pulled them and put some locktite on the threads and back in. Took 20 minutes total from start to finish. I could probably do it again in 10 minutes. My column is 100% wobble free. :)
Thanks guys!!
Reactions: Bad Sheep
