I just got this info on the TKO 500:
Ford Conversion:
The Ford versions (TKO-500 TCET4615) and TKO-600 TCET4617/5008) come with the following modifications to specifically fit your Ford:
late model Ford 26 spline 1 1/8” input shaft. These are the late model Ford input shaft, and ‘early’ Ford input shafts also available through from us (JAM Performance Transmissions)
Ford bearing retainer to allow it to fit right to your late model Ford bellhousing!
Ford bellhousing bolt patter to allow it to borlt right up to your late model Ford bellhousing!
Stock Ford transmission mount can be used.
Your stock Ford speedometer adapte will work with this trans, and an electronic speedo sensor is also available.
Note the Shifter: section below.
We also offer upgrades for FE and ‘early’ Ford applications, as well as 3rd Gen GM F-Body conversions.
So does this mean that the TKO500 will just bolt up no problem? I'm not sure what style imput shaft is on the car now, but if I'm reading this right then all I need is the tranny. My T5 is hurting bad after my dyno runs the other day, this project has just been moved to the front burner. I want to know what I need other than the tranny, IE- clutch, clutch fork, driveshaft, etc. Please help me out.
Ford Conversion:
