Ok. It's finally in and just testing it with windshield washer fluid I picked up 1 MPG. Last night I replaced that with -20 washer fluid and one bottle of Heet starting fluid. Now I just have to fit the correct nozzle and adjust the pump pressure to get maximum chamber cooling and octane boost.
The low-rpm/low-load pinging is all but gone except the tiniest bit on tip-in until I run it WFO. The 3-step-colder-than-stock spark plugs may have helped a bit too. They dissipate heat from the chamber better but with them and the initial squirt of alcohol on start-up when there's no vacuum cold starts have gotten a little rough. I may need an arming switch. Got the perfect place for one since I don't have a convertible.
I'll update again when I adjust the flow and flash the 100-octane tune.
