nail in tire...patch?
Smeech
148
Fremont, Ca
I have a nail in my rear tire... right in the middle (treads). I searched, but couldn't find anything... I assume a tire shop can patch a tire of this size (295/35/18). Has anyone run into problems with tire shops not doing this for some reason?
I just plug my tires myselfs. On my GT I got a nail in the rear tire right in the middle about a year ago. I didn't even take the tire off the car. All i did was pull the nail, rasp out the hole a bit and insert a tire plug and filled it with air. It's held fine every since.
I've plugged many tires, and have yet to have a problem. I even keep a tire plug kit in my trunk, which i have used to fix friend's car's tires
If it's in the tread pattern, it is very very easy to "plug" the tire, in fact, a nail is probably the easiest tire fix there is, more than 99% of the time the plug will hold perfectly. They use an extreme kind of glue also, it should cost you under 20$. At the most they may charge a fee for a Mount/Balance on top of it.
I've successfully plugged every tire i've ever pulled a nail out of, probably like 6-8 times total. It's very simple. While you're at it yank your valve stem left, right, up and down and listen for a leak, or put a little water on it first, replace it if it leaks, cheap and may as well when repairing a tire, I always do. Also very simple, just need a razor blade.
No way, a plug for a nail is far superior in every way to a patch. It will last the life of the tire in virtually every case, and the "plug" wears down along with the tread. Unbeatable. Simple.
Typical, average price, around 8-15$ at a tire repair shop. If you go to a shop that specializes in other stuff and ask them to do it, they may charge a bit more, or not even do it. Anyways, if you can dress yourself in the morning, you can probably plug a tire. It's very simple. Now that I think about it, I dont think i've ever had to take a wheel off a car to do it.
merc123 said:
$10 for a plug? Hell they patch in my area for $12. $7 for a plug. I just bought the plug kit and do it myself. You can get 5 plug strips for about $5 or $6.
Sorry I was $3 off :rlaugh:
Plus CA is ghey, so everything is more expensive. Not to mention uber ghey smog laws and no 93 octane gas!:nonono:
a plug should do you fine for a nail, i have like three in my tires right now because of a construction site that i have to pass on my way home, so i usually drive around with a plug kit and compressor just in case
i work at a tire shop and specialize in low profiles and custom wheels and plugs SUCK!!!!!!!! they last about 3 to 6 months and the glue wears off and starts leaking patchs or pull throughs my shop wont plug causes seperation
yea heck just go to walmart purchase urself a plug kit and it comes with like 10 plugs and do it yourself its not hard at all. On my stock tires i got a nail in each one of the tires some tires had two nails in them lol this was all overtime though. I hated those tires they picked up every nail and i wouldnt drive in any construction or anything.:nonono:
