need a brake job, and some advice
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
im trying to decide what to do about my brakes. theyre down to the squealer and i could either cut the rotors and buy new pads, or do a complete replacement w/ 13" cobra brakes. of course the 13" will be more expensive. about $500 total. my other option is just paying ~$100 for some new pads. what would you all advise i do? if i did buy the cobra brakes, i would have to put them on credit and pay them off w/ my 20% APR :fuss: if i did go with just new pads and cutting the stock rotors, what brand/model brake pads would you recommend? what would you do?
open bleeders !
"what ever you do open the bleeder valves front & back before compressing the pistons" , also change all the fluid ...flush it till its clear ! the fluid goes bad ....bleed it starting at the rear ....passanger then drivers side , then the front ... I used all stock stuff on my 99 GT , the new fluid helps DOT3 or DOT4 the higher the DOT # the more heat the fluid can take ...opening the bleeders is important because you dont want to force fluid back into the anti-lock & other valves ....take your time 2guys maybe 2hrs then road test easy till they set in ........ good luck :nice:
Black2001GT said:
You should be able to find a complete 13" Cobra front brake kit that includes,
Rotors, Calipers, Steel break lines, Banjo bolts and pads for around 400 bucks.
i found the cobra kit on ebay for $399. i want the slotted rotors instead of plain though. so add ~$59. then shipping is ~$30. over $500 now :notnice: any other places you can think of?
thanks a bunch to Kilgore and Black for all the links! i just need some time now to read :D
tomustang said:
fuggit, get the panhard bar!
:hail2:
but
safety > fun
dsg_gt2004 said:
Oh No Derek Misses The Ups Guy
hells yeah! i havent seen ma boy in over 3 weeks! he always has a nice comment about my car :nice:
dsg_gt2004 said:
what is a good milage to replace the brakes at..im coming up on 40,000 and im thinking that time is nearing soon.....maybe 45,000?
i just hit 35k and im almost down to the squealer. i just checked. its very close. its hard to hear though with my exhaust being so loud :D i have to let my engine idle while moving and then hit the brakes at idle just to have a chance of hearing.
Black2001GT said:
Is the Ebay deal better than the Speed Concepts deal?
the speed concepts is $10 cheaper, but ive heard bad things about speed concepts. :shrug: i talked to a guy on the phone and he seemed nice enough. now that i looked at that kit, im still up in the air
