Ok... there are so many threads on how to properly adjust a clutch cable.... but here is how I did mine... I always adjusted a cable clutch by how the pedal feels. Right now I have no free slack in the pedal. There is a soft spot until you get about even with the brake pedal, when it gets a real firm area, then goes down pretty easy after that. This normally worked ok for me.
Now, here are my two problems: 1. When I let the clutch out completely, I can barely hear it making the tiniest noise, this is ok, right? or should it be completely silent? And 2: When I push the clutch all the way to the floor, and move it back and forth about an inch, it is making a squeaking noise, and this is when the car is off, not running. Im not sure if something is rubbing, or if there is something wrong with the adjustment. I have a summit racing adjustable cable, because my first one broke (Found out that it was probably binding up on something after seeing how easily new cable disengaged clutch.)
