Need a little help
-ben-
21
Ok... there are so many threads on how to properly adjust a clutch cable.... but here is how I did mine... I always adjusted a cable clutch by how the pedal feels. Right now I have no free slack in the pedal. There is a soft spot until you get about even with the brake pedal, when it gets a real firm area, then goes down pretty easy after that. This normally worked ok for me.
Now, here are my two problems: 1. When I let the clutch out completely, I can barely hear it making the tiniest noise, this is ok, right? or should it be completely silent? And 2: When I push the clutch all the way to the floor, and move it back and forth about an inch, it is making a squeaking noise, and this is when the car is off, not running. Im not sure if something is rubbing, or if there is something wrong with the adjustment. I have a summit racing adjustable cable, because my first one broke (Found out that it was probably binding up on something after seeing how easily new cable disengaged clutch.)
For number two, do you think it's the pivot bushing for the pedal?
I wouldnt sweat #1 but I havent had the issue myself.
Where is the point of engagement? SOunds like it's at about halfway down or a little more.
Good luck.
