Need Advice
  • Thread starter Thread starter mustangfan1990
  • Start date Start date Apr 17, 2008
mustangfan1990
505
Lenoir, North Carolina
Apr 17, 2008
  • Apr 17, 2008
ok this friday I am going to get my car retuned so I can hopefully take it higher than 4500 rpms and get close if not over the 500 rwhp mark. I do have a pair of MT drag slicks that I run at the strip that hook to the bone. Now on motor I wasnt to worried about it, but these slicks DO NOT spin no matter how hard I launched. I was thinking should I get some longer wheel studs? If so how long and how do you put them in? I have never done it so I am not sure how to do it. I think you knock them out the back side right?
Rick 91GT
Mustang Master
95
99
PA
Apr 17, 2008
  • Apr 17, 2008
You'll snap the axle before you shear the studs in many cases.. You can buy NMHR legal 3" studs from ARP, MOROSO etc... They get pressed out through the backside, you just need to pull the c-clips and slide the axles out to do it. They may or may not fit under you stock center caps depending on which wheel you run.
I assume you already got your fuel pump?
mustangfan1990
505
Apr 17, 2008
  • Apr 17, 2008
yeah I got a walbro gss 307 for 90 bucks at the charlotte autofair
88mouse
630
Mooresville nc
Apr 17, 2008
  • Apr 17, 2008
are your slick screwed? If not they may spin the rim in side the slick.
mustangfan1990
505
Apr 17, 2008
  • Apr 17, 2008
No they are not screwed...how will I know if they are spinning inside the tire
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,119
224
Massachusetts
Apr 17, 2008
  • Apr 17, 2008
Have you upgraded the rear end at all?
What trans are you running?
mustangfan1990
505
Apr 17, 2008
  • Apr 17, 2008
lol I know what you are going to say dont worry about the wheel the tranny wont last.....my no it is all stock. the rear end is stock and the tranny has been rebuilt with a world class kit and the clutch is stock. I am sure they wont last long but I think it will last atleast a couple of times. There is a guy near me with similiar setup but I dont think he has as much as I do and he runs like 7.6s with the same stock parts I have and some...
88mouse
630
Mooresville nc
Apr 17, 2008
  • Apr 17, 2008
Take something and mark the tire at the valve stem before you run. And after you run see if the mark has moved away from the valve stem.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,119
224
Massachusetts
Apr 18, 2008
  • Apr 18, 2008
Well 500 rwHP is a lot. You are right, they may hold up for a while..but something going to let go. I'm thinking an axle shaft first.
FYI, all Mustang transmissions are World Class. It has nothing to do with strenght. It refers to the 3-peice synchros. Even 4-banger T-5's are World Class.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Apr 18, 2008
#10
  • Apr 18, 2008
  • #10
Don't bother with wheel studs in stock axles. Just get better axles that come with better wheel studs.
Your current drivetrain setup sounds like a timebomb if you use slicks.
Just remember this, a good running t5 is worth $550 or so, a broken one is worth $100 or less.
And if you break an axle the tow home is going to be $100 depending on mileage.
I'd consider running on a different tire, hell you may ruin the traction lock in the burnout box with slicks.
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
