need answer quick, buying Tuner question
Jbauer
506
i've got like 10 minutes to bid on this to win.
It's a tuner. It's got a 93 octane tune from an 04 GT on it.
I've got a 00 GT.. can i use the tune on this tuner? or do i have to download a tune for my 00GT from diablo?
Thanks!
I don't really care if anyone tunes with it or not, i only want it to correct the gear ratio for the 3:73s and to get the extra 5-10.
you mean the processor number on the cars ECU? They probably are diffrent..seeing as its 4 years apart.. i guess i'll find out soon.
I'm not making any timing/fuel adjustments. I don't want to screw around with any of that unless i decide to get a cam or something, and then i'll get it done professionaly
All I just want is to install a standard 93 octane tune on it and adjust for the gears. you think i'll be fine with that?
Thanks
those look cool.. about 200 dollars for both. but i still wouldn't get the 15HP/tq.
I'm not too angry with this tuner, as long as it installs. some people pay like 400 dollars for these things, so if i pay 200 i'm happy
A Steeda Timing Adjuster bolts on & allows you to mechanically advance yr timing so you can burn 93. Gotta be some HP there.
Be verrry careful with that new tuner if you're practicing brain surgery w/o a license. It can turn your ride into a 3000 lb paperweight in a flash (pun intended). :)
Good luck.
