Its best to use an inside compressor, and to make it even easier you can modify it.
Just unscrew the bottom arm off the shaft, and remove the upper arm also.
Get a 10-12" piece of 2x4 and drill a hole in the middle of it for the shaft.
Put a large washer (there should be one at the top of the compressor anyway) on the shaft and run the shaft through the 2x4, then screw the bottom arm back on.
After removing the shock, run the bottom arm down through the top of the shock tower.
Hook the lower arm to the spring and tighten the compressor until the spring is clear.
What this does is get all the compressor parts out of the way and gives all the control to an easily accessible shaft up on top. It also makes it nearly impossible for the compressor to slip off the spring, since its anchored by the shock tower.
Best to use dry pressure treated wood, if you have a scrap piece around. This is much easier that it sounds...
Good Luck!
