Hey folks, I need to be planning an engine rebuild for next year. I have an '86 with the stock 5.0 with about 143,000 miles, and I think I want to pull it out and rebuild it instead of buying a used engine. I just want to know what I have. Please keep in mind that this car is a daily driver, with a trip down to the track a time or two. I want the car to be reliable and driveable, but I want it to be faster than a stock or average 5.0. I don't want nitrous or anything like that right now. I want to add a blower at some point, so I don't want to cut corners now.
My questions are: I assume that while I have the engine apart, I should go ahead and install an E303 cam and have the pistons cut or replace the pistons so that I can run maybe twisted wedge heads or something other than the non-flowing '86 heads I have now. Correct?
Also, should I upgrade or replace the rocker arms, etc? Should I go with 1.7 or something like that? If so, what brand to you guys suggest?
As far as rings, what should I go with that will stand up to a little abuse but hang in there for the long haul?
Should I go ahead and upgrade the injectors, regulator and fuel pump? If so, how large an injector should I go with?
I don't want to put a ton of money into it, i.e. blower and stuff like that right now (want blower later) but I want to do it right and I don't want to cut corners. I also want to build a good foundation to add a blower at some point down the road. I want to get the engine to where I don't have to add oil every 200 miles (doesn't smoke now, but I think it's getting sucked up by the PCV) first, then I'll do suspension and brakes, then I'll start adding more go fast stuff after I get another daily driver.
I value your opinions on here...that's why I posted. Thanks!
etc
