Well today I went to dynoed my car for the first time since,I bought the car already modded..so my numbers were 285rwhp and 295tq on a dynojet..now the problem is that I have a novi 1000 boosting 8psi,and I think is really low since similar combos are running 370ish..the guy that did the pull said that it shows the 8lbs but he didn't know why it was low,...and that I can do a tune with them etc etc......so I would really appreciated if somebody has an idea of why it dynoed like that.. my mods are:
Novi 1000 rr 8psi
lightning 90mm mass
Anderson powerpipe
C&l pipes and plenum
Bosch bypass valve
42lbs injectors
Kenne bell boost a pump
Pypes x-pipe with high flow cats
Spintech mufflers and catback
Diablosport delta revolution chip
Also car is a 5 speed manual
It was done at a dynojet dyno, at 46 degrees temp,and 61% humidity, guy said that the airfuel looked good,
Thanks for any help you guys can provide me
Posted via Mobile Device
Novi 1000 rr 8psi
lightning 90mm mass
Anderson powerpipe
Bosch bypass valve
42lbs injectors
