Ok guys here's the story,
I finally got my engine in, and last night when we got done, we cranked the car over, and it fired up, but wouldn't idle, which I kinda expected. so we tried to get the base timing and ***** straightened out, but with the compression, and the old battery, we didn't have enough juice to get it goin again. So this morning I went and got a new battery, but the car wouldn't start. we narrowed it down to a fuel problem, atleast I think. The Pump works, and we have fuel pressure, but when we tested the injectors with the test light, we got nothing until we grounded the injectors out. The injectors are spraying, but seem to be very weak. I am at a complete loss for words and desperatly need somewhere to look . Thanks for all ur help guys. here's a list of mods:
MSD Ignition
BBK shorty headers
BBK high flow H-Pipe
Flowmaster American Thunder Cat-Back System
AFR 165cc Aluminum Heads
Trick Flow Track Heat Intake Manifold
Ford Motorsports E-303 Cam
Crane Adjustable 1.6 Roller Rockers
Pro-M 75mm Mass Airflow Meter
Ford Motorsports 24lb. Injectors
Kirban Adjustable Fuel Pressure regulator
Canton 7 quart Double Sump Oil Pan
Melling High Flow Oil Pump
BBK Cold Air Kit
Probe Forged Pistons (9.8-1 compression)
Forged I-Beam Rods
Lunati Roller Lifters
Comp Cams Hardened Pushrods
Flow Kooler High Flow Water Pump
new cap and rotor
Lenny
MSD Ignition
BBK shorty headers
BBK Cold Air Kit
Forged I-Beam Rods
new cap and rotor
Lenny
