  • 1994 - 1995 Specific Tech
Need help, car won't start!!!
  • Thread starter Thread starter defacto_pr
  • Start date Start date Oct 9, 2005
D
defacto_pr
178
  • Oct 9, 2005
I've been having this problem for around a month. After letting the car idle for 10 mins, the rpm's would start to hunt for idle. After 20 minutes, if you give some gas the car would die. If I tried to fire it up right away it would not start and had to wait around an hour for the car to start up. The panel lights up, tried the night lights to see if it's battery related, but the starter won't do anything (no sound, click, etc...). The starter was replaced but my problem didn't stopped. Today I fixed the idle situation. After letting the car idle for more than an hour (and turning the car off and starting it again 3 times), I took the car for a drive around my neighborhood. When I got back home I turned the car off. I tried to turned the car on but, once again, it did nothing. After 40mins the car fired up as if nothing had happened. What could be causing the problem?
FYI: I changed the AODE for a C6 with a manual valve body but the TR is the one from the AODE (I'm using a Tweecer). Could that be a place to check?
HISSIN50
34
129
Oct 9, 2005
  • Oct 9, 2005
I am not sure why the TR would be at fault but it is worth checking. You could have a poor connection and the heat is taking it out (I have seen this on starter interlock circuits before, but I live in the desert with extreme heat).
Otherwise, if you are pretty sure it is an interlock issue, start tracing from one end to the other (ignition switch to the starter solenoid).
Another possibility is heat soaking of the starter. That does not seem to affect the SN guys as much as fox guys, but you have a nice sig and are making some power (and heat).
Do make sure your battery connections are good. once again, heat raises resistance in wires and a marginal cable (cold) will be insufficient once hot.
Good luck.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
