Need Help from 427 stroker owners!
  • Thread starter Thread starter thehueypilot
  • Start date Start date May 30, 2004
thehueypilot
1,084
Medina,Tennessee
May 30, 2004
  • May 30, 2004
I just switched from a performer RPM intake to a new Victor Jr. intake and my ET and MPH dropped off. Best time with the Performer RPM was 7.58 at 92 MPH and the new combo is 7.80 at 89 mph. I have a "quick fuel" 850 w/vac sec carb. (Yes the sec. are opening up fully.) I started out with 80/88 Jets but the plugs show to be very lean. I am now at 90/96 and they still seem a little lean. The car does not feel faster and I am at a loss for this change taking me in the wrong direction. What are you guys running with your 427 strokers?
F
fastcoupe68
368
nj
May 30, 2004
  • May 30, 2004
It is very hard for me to believe that you have encountered a problem. I aways ran a 750 dbl pump on 400cubic + small blocks and never had a problem. Are your secondaries opening soon enough? Maybe a vacum leak?
SandSprite
332
L.A., CA
May 31, 2004
  • May 31, 2004
Where are you shifting at?
D
D.Hearne
11,730
south louisiana
May 31, 2004
  • May 31, 2004
The Performer RPM gave the motor better bottom end torque. That's what you needed to pull the 1/8. I'll bet running a 1/4 mile, your time would have improved with the Vic Jr.
T
TT670
360
9
28
May 31, 2004
  • May 31, 2004
IMO an 850 is way too much carb. If your car is a stick It'll go faster and your leaness issues will go away with a 750 dbl pumper.
allcarfan
The Answer Man
2,458
North Atlanta
May 31, 2004
  • May 31, 2004
DHearne said exactly what I was going to. You will have picked up some time in the 1/4. Im not that surprised you lost some in the 1/8th. You probably will have to spin that engine a little high too now.
3spd on floor
1,099
Acworth, GA
May 31, 2004
  • May 31, 2004
in your sig it says you've got an 8 inch rear? how in the hell is that holding up to hard launches with a 427w?
thehueypilot
1,084
Medina,Tennessee
May 31, 2004
  • May 31, 2004
The car idles good and runs smooth thoughout the RPM range. I shift at 6K during my run. The car lacked power at the end of the run, hence the change to the vic. jr. I noticed when Mustangs and Fast Fords did their story on high flow cylinder heads they ran a 1000+ cfm carb. I have AFR 225's which flows volumes of air. The rear end is a four pinion "Currie" unit that is too small for the power I am putting to it, but it is hanging in there so far. The 9 X 24 slicks help relieve the strain some what since my 60 foot times are only 1.70. I am at a loss for increasing the jets to 86/94 to get rid of the lean condition? I have not ran since this change.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Need a clutch, 1982 Capri RS 5.0 owner, am I allowed to participate?
  • scudzuki
  • Apr 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
T
1989 GT Possible air/fuel issue
  • Tim83
  • Jul 22, 2022
2K
Fox 5.0 Mustang Tech Jun 26, 2023
Tim83
T
