Need help installing these 2 things? pics
95Vert said:
What about the c/c plates? I know how they sit, but I don't know how I put the strut through them and make them stay.
You gotta get the stock ones off first. Then you can reuse the strut nut and slide the strut though the new CC plate and secure it with the stock nut.
95Vert said:
Ok. So I'll put the strut throught the hole in the c/c plates. Then I place that rubber thing, then the top plate(round one), and then secure it down with the nut. Right? OF course, after removing the stocker.
When you say rubber thing are you talking about the offset rack bushings? If you are then no those go down on your steering rack.
Yep - the stock top rubber "donut" is not used on your new Plates. Ditching that donut (for a poly/rigid bushing that comes with your CC plates) helps keep the top of the strut located, which is great for handling.
Enjoy!
Pretty much. Did you get the metal bushing/spacers that go around the shaft so it doesn't wobble? I'm taking a guess but they look used just wanna make sure you got everything your suppose to have before you tear it apart.
Oh and you should have a bushing between the nut and plate they say you should only have so much of the threads sticking up
what is this! a dirty mess
95Vert said:
OK. I think I understand you guys, but let me recap.
Take off old c/c plates.
Install new ones on frame.
Run strut through hole of c/c plate.
Just tighten the nut without anything in between.
Take to alignment shop.
Go crazy around corners.
Drink Beer.
Go to sleep.
add this to the list, clean all the dirt and grease out from under the hood.
this is what it should look like...now get to work!
:lol:
I know what you mean, but I spent one whole day cleaning my engine bay not too long ago and it only lasted about 2 days clean. I kicked my ass for that. How do you guys do it to keep them clean if they're your d/d?
MM, where can I get that bushing you talk about. All I've got is what is in the pics, nothing else. Any pics of what else I need.:nice:
