need help, rear diff question....
About to run this shatstang off a cliff. Please can anyone tell wut rear diff. Or pretty much the whole rear end will work in replace of my 96 gt? Got some serious noise coming from the back. Had it looked at by a mechanic. Said they'd fix it for 900-1100 dollars depending on wuts going on in there. So I'm at an end with car.. so I'm going to a junkyard and putting the rearend in myself. Got to be cheaper that route, then selling this Damn lemon!
Go to car-part.com and search local salvage yards. The web site will also help you with model year interchange.
However, the problem with a salvage yard rear end is that it may not be any better than the one you have.
A small shop should be able to rebuild a rear end for $650 or so.
I did mine myself for $125 in parts and $80 in machine work. However, getting the gears set up correctly is not for the unprepared.
A rebuild rear end will include all bearings and seals. For all practical purposes, a zero mile unit.
iirc,explorer rears have different shock mounting points,not to mention set up for leaf springs and drum brakes.
easiest way would be to get one from a 94-98 mustang gt or cobra.
check craigslist,or your local wrecking yards.
