Need help removing broken copper pipe
diablostang
425
Raleigh, NC
Here's what happened. I've just finished up putting a 89 engine in a 94 Mustang, among the differences was the oil-sending unit pipe. When I put the A/C & P/S bracket on, it broke the oil sending unit pipe, thus creating a BIG oil leak when I fired the car up. I carefully tried unscrewing the pipe, but it was too far broken... The end is now in the block still.
Need suggestions on how to remove it without drilling it out? Bear in mind this is in somewhat cramped quarters, below the A/C and Power Steering bracket, by the oil filter.
Stop by your favorite parts store and pick up an easy out. You can take your piece of copper pipe with you to ensure you get one that fits well. You'll usually find them in the same section of the store as the Heli-Coils. Using some heat to break the threads loose first might be a good idea so long as you don't burn the car down.
An alternative (if plan A doesn't work) is to drill the copper out as close to the threads as possible (without damaging the threads) then pick out the remaining copper with dental tools (or some reasonable facsimile thereof).
Good Luck
