Need Help tuning?
Blackgtmustang
183
Indiana
Here is a list of my mods... 4.30 gears, 1in 5/8 long tubes MAC.. shorty h pipe and mac catback.. CAI, 75mm mass air 70 mm tb 24lb injectors ,Trickflow track heat intake, trick flow cam .. 306 bottom end, Stage 3 ported heads.
I ran a 8.81 @ 80 mph before the ported heads and the longtubes..
I just put the Longtubes and Stage 3 ported heads on.. Its runnin about the same as it did before... What kind of Fuel pressure do you think i should be runnin.. im goin to set my timing to 16 and run some blue.. im thinkin its just in the Fuel pressure...
and btw what times do you think i can run with the new setup?
