Need help Upgrading Up Grades...
Well this past winter i cracked my upper intake by letting a friend help with the install and he over tightened a bolt and cracked it....so now i'm in the market for a new intake with the help of his wallet...and some of mine...Just need help on deciding what to replace it with.... Looking at TFS Street Heat, or 5.0 Proformer
Also i have about 1100 to spend on other random stuff so any suggestions would be GREAT...i've only got 2 weeks to add stuff and get to the track b4 i have to be back in Korea :-\
Mods are as Follows:
GT-40P Heads with Matching Headers
Explorer Intake........Needs replace hence the thread
TFS 1" Intake Spacer
Explorer TB 65mm
BBK 65MM EGR Spacer
Unknown cam was in the car when i bought it has no markings at all on the cam...idles close to a B cam
Crane HI-6 Ignition
Bassani X-Pipe
2 chamber Flows and turndowns
SMOG and AC Delete
180* Thermostat
K&N Filter
3.73s
Steeda Triax Shifter
King Cobra Clutch with Steeda Clutch cable and firewall adjuster
Combo looks nice and stout..you could look to suspension upgrades. I redid my suspension/upgraded my control arms/replaced bushings, and can't believe how much the overall driving improved on the car..hell car felt crisp and new again.
tmoss said:
Let him fix the Explorer and keep it........
Pull the lower and send it to Tmoss to be ported. While the lower is off being ported, take the upper to the welding shop. Plan on taking it to the machine shop after the welding is done to get it resurfaced and flat for a good gasket seal. That makes for a hard to beat combination that leaves $$$ for other goodies...
