need help w/balancer removal tool
rrl
92
i bought the tool from sears and none of the bolts they supply go into the 3 holes to pull it out the balancer.its a 02 gt and the 8m - 1x25 bolts supplied with the tool won't go in.i read on another tread thats the right size bolt but i'm afraid of stripping the bolts or the balancer.what is the correct size or let me know what i'm doing wrong.thanks!
go to www.mustangworld.com and check out the how to's on how to install pulleys, the bolts should thread easily, be sure to put a dab of silicon in the notch when you put it back on, you should look for some different sized bolts, i'm suprised that they didn't give them to you with the balancer, you might need to take a trip to the hardware store
