need help what cam to use?
hernandez
44
I just ordered a 347 stroker, the pistons are made for the twisted wedge heads that i got. I have the E303 cam, but i was wanting something bigger, little more aggresive. this is what i have so far gt40 u/l intake, track heat heads w/ 1.6 rr, 24lb injectors w/70 mm maf, 65 mm t-body and spacer, CAI, long tube headers, custom made x pipe, slp loudmouth mufflers, 3.73 gears, t-56 trans, u/l control arms, and now a 347 stroker kit on its way. should be at my house next week. i have to find a good cam for this set up, thanx:flag:
hernandez said:
what is the idle like on the stage 2 cam from trick flow, and specs
here is all the info from www.trickflow.com
part #= TFS-51402001
Characteristics= Fair idle, good midrange power. 2,500-3,000 rpm stall converter or five-speed recommended. Compression: 9.5:1 minimum
duration @ .050 224/232
valve lift with 1.6 rockers= .542/.563
LSA= 112
you will need springs that will hold that lift
my compression on the stroker kit will be like a 9.2:1, i want it low but not to low, next year getting a hellion turbo kit, will the trick flow stage 2 cam work with that compression
