need help with defrost window
jcpower
10
2000 mustang V6
hi guys i really need help i have a leak that seems to come from the defrost window thru the inside on the vinyl, look like i have mi own water front behind me car, so would you tell what cause the problem and how to approach, thank you
water front huses is the hause that have a lake behid the propety i don't know why the called water front when the lake is in the rear of the house, so any way i was try to say a joke, would you help with the problem
reply for all the 5 yr olds
now that everyone is done making fun of the way I write english do you think we could act like adults and work on the problem I have? I have a leak in the rear window and I have a puddle of water behind the rear seat where the convertable top goes. Is that fixable or does the whole thing have to be replaced?
all in good fun.. and to be fair i thought you were talking about the defrost grid on the rear window
If you're sure the water is coming through the window, get some silicone and apply it to the seam around the window- on the inside of the convertible so it's not visible. That should stop water from coming in around the window.
