Need help with my new setup
  • Thread starter Thread starter raulbadillo
  • Start date Start date Sep 4, 2008
First Prev 2 of 2
P
phutch11
328
Sep 7, 2008
#21
  • Sep 7, 2008
  • #21
Just one question - what did you use that ball peen hammer that's laying near your intake for??
Joking aside, you're going to be fine. Just track down the different vacuum hoses going from each element in the schematics posted above - when you find the vacuum hoses that aren't connected to anything, connect them to the manifold vacuum ports. Cap off any remaining manifold vacuum ports that aren't used. It'll take a while, but you'll have an intimate knowledge of your car's vacuum system.
As to the lower manifold gasket - don't worry about the RTV you put on there. Some guys put them on dry, some dab the RTV at the corners and others just toss away those gasket pieces and just use a thick bead of RTV sealant. As long as you've got your lower torqued down well, you'll be fine.
Good luck.
dcurtis
688
Sep 8, 2008
#22
  • Sep 8, 2008
  • #22
The two small lines are for the fuel pressure regulator and the other goes to the passenger side in the vacuum line bundle that has the tab tad solenoids in it, I thing it hooks to the line that goes to the egr solenoid.
R
raulbadillo
51
#23
  • Sep 8, 2008
  • #23
Good, i did find the vacuum hoses but now one is too short. the one that goes from the Fuel pressure reg. to the upper manifold. Any suggestions? And the ball peen was for my head when i had a head ache........and talking about torque on the lower manifold. Um i used my air compressor to tighten them. Is that bad? I dont have a torque wrench but i can go get one and redo if I have to. I dont know the torque specs and i havent started the car yet. Waiting on a EGR spacer before i run the vehicle.
Boostedpimp
20+ Year Stangneter
May 8, 2003
1,451
493
154
NJ
Sep 8, 2008
#24
  • Sep 8, 2008
  • #24
Just go to a auto parts store and pickup some vaccum line.. bring the short piece with you so you know what size OD you need or if you've deleted anything from your engine bay maybe you can reuse lines your no longer using.
Over torquing will damage the gaskets and you won't have a good seal or the gaskets will let go prematurely on you.. Rent or invest in a torque wrench and torque them to spec according to what trickflow recommends or go by the factory suggestion... also there is a certain pattern to torquing down the lower intake bolts which should be followed as well.. kinda like install lug nuts on a rim.. you don't just tighten whatever pattern you want know what im getting at now
R
raulbadillo
51
#25
  • Sep 8, 2008
  • #25
well thats not good lol. Any idea where i can find the torque specs and the pattern?
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Sep 8, 2008
#26
  • Sep 8, 2008
  • #26
My experience with an old car, says never use an air compressor to tighten anything on the engine. You need to feel whats going on.
Suspension-yes
Engine-no
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 8, 2008
#27
  • Sep 8, 2008
  • #27
See Ford Mustang: Mustang Tech: Engine: 94-98 5.0 torque Specs for bolt torque specs
Bolt torque pattern -
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
R
raulbadillo
51
#28
  • Sep 11, 2008
  • #28
the torqe specs are for a 94 to 98 mustang. will they be the same for my 89 five oh?
Boostedpimp
20+ Year Stangneter
May 8, 2003
1,451
493
154
NJ
Sep 12, 2008
#29
  • Sep 12, 2008
  • #29
I would say yes since the 94/95 stangs had the same old push rod 5L motor in them as your 89 does
Boostedpimp
20+ Year Stangneter
May 8, 2003
1,451
493
154
NJ
Sep 12, 2008
#30
  • Sep 12, 2008
  • #30
also be careful with the bolts because using the air tool on them may have over torque them and you could very easily break on off while reinstalling and torque them to spec now.. happened to me and sucked major
First Prev 2 of 2
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Idle issues….again.
  • Nostang25
  • Sep 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2025
AeroCoupe
