First off im a newbe, i just bought a 1994 mustang gt the mods are 306, trick flow street heat manifold,e303 cam, bbk cold air intake,blue top injectors(i dont know if they are stock i was told 24lb,adj. fuel pressure regulator, also i dont know if my mass is stock but the only marking on it are japan and the bbk air filter fits right on it, Anyways i have had nothing but idle problems with the car. And it seems like the car is lacking power. The check engine light comes on and then goes off and had it checked and it came up 4059 with they could not tell me what code that is??? I really just need this thing to idle right. also i had cleaned my mass and throttle body some of the questions i have are..
what should my fuel pressure be at?
what should my timing be at for best performance?
what is the error code that i am getting?
what would you guys suggest i do to get rid of this idle problem?
i know this is alot of problems but i just need help before i bring it to a shop and end up sending lots of money to get this fixed. thanks alot for any help you guys could give me.
