yes clear it last with 4 coats then wet sand with 1500 and then 2000 grit.
1 Wet sand old paint to level imperfection.
2 Use touch up paint if needed.
3 Wet sand spots that were repaired to match the rest of the paint.
4 Make sure that the surface is clear of debris and oils.
5 Spray 4-6 coats of clear( I used duplicolor truck, van & suv clear coat, picked up at discount auto).
6 Wet sand clear with 1500 then 2000 grit(should look hazy)
7 Wax it/ buff it/install it.
Its best if you take them off the car.
Also make sure that before you spray with clear clean the lights with acohol, or cleaner. I made the mistake of not doing this and right and I had the clear start flaking off in a 3"x3" area so last night I took the one off and followed those steps and put it back on today before work. looks great now.
It will take you a couple hours just to let you know.
