Progress Thread Need Opinions On 302 Upgrades
Johhny J
15
I got about 2 grand to spend. Im wondering what your guys opinions are on the best for your buck upgrades. This is whats been done to the motor already.
CI: 302
Fuel: 24 lb fuel injectors, 255 LPH Fuel Pump
Intake: GT40 lower-upper intake
TB: 70mm TB
MAF: BBK 76mm Mass Air (Calibrated for 24 lb fuel injectors)
Exhaust: Long tube headers to Flowmaster 44s (2.5 inch pipe)
Cam: F303 Cam
RR: 1.6 Aluminum RR
Coil: MSD TFI Performance Coil with 8.5mm Super Conductor Wires
X2 heads and a custom cam. Check with FlowTechInductions.com,Bullet cams,or a few others(Brian Friedentag,Buddy Rawls,etc). You can buy the heads already setup to the cam profile if you use Ed(owner of flowtechinductions.com). I'd actually recommend some tfs heads over the AFR 165's but the AFR heads are a solid choice.
Custom grind cam.
If funds are left over, have tmoss port the lower to match the heads. With gaskets and fluids you should be around the $2k mark and have a stout combo
Subframe connectors, 5-lug swap, Cobra 4 wheel disk brake upgrade, New coil springs and shocks..
I know you wanted engine upgrade recomendations-but they already have that covered,so here's my recomendations for the next 2 grand :) lol
the 302 is in a 67 mustang
Ive been reading a bunch about trickflow vs afr, i cant figure out which ones are better. So far ive come to the conclusion that both are just really good heads. I did hear that with a lot of the trickflow products. they all have to be matched. Heads, pistons, rods all have to be trickflow brand.
Well. Most of what I said is still relivent .. lol
Not true. There is a lot of misinformation out there. TFS doesn't help with some of their advertising etc. In some instances a specific piston may be needed because of their brand specific valve angles. This is only truly needed in specific situations. The reason i recommend tfs over AFR 165's is the bigger valves and potential for growth. There is more material to work with if ever needed. But if you just want a 300-375 hp motor and never truly intend to go above that(n/a application) then either the 170cc tfs head or AFR 165 are fairly equal. Some have made more power with either product but have truly dialed in the combination of parts needed/tuning etc.
For a typical 302 build with stock "styled" pistons you just need to be mindful of cam timing events. The avg owner can run a lot of "typical" roller cams. Most clear in the PTV (piston to valve) clearances. A custom cam can actually be designed with significantly more lift for example than the avg off the shelf cam profile. It's all about when those events happen. Obviously you want the timing events to be correct when the piston is at the top of the cylinder(TDC). That is when bad stuff can happen. The valve can lift a lot when the piston is traveling up and down. Also valve springs must be matched to the cam profile. You don't want soft springs that can cause valve float etc.
The cam designer can dial in all these considerations for max benefits. You want to be able to fill the cylinders with the maximum amount of air as possible. A lower duration/high lift cam is a great option with mild manners,greater efficiency and in return more power. You'll need to tell them exactly what parts you are using,intended usage of car(drag,street,some of each,etc),trans type,rear gear ratio,type and sizing of headers/exhaust. Typical OTS cams run around 2-300$. A custom will run around 350-400$ depending on what material they make the blank out of and the manufacturer they use.
Reactions: RaggedGT
