Need parts list for 03 Cobra fuel system setup
I'm looking to add an 03 fuel tank/pump set up to my 99 s/c Cobra. Can someone that has done this give me an exact parts list of what I will need? I know I need the tank, the dual Cobra pumps.....what other things do I need? (lines, straps, bracket, ect...)
Thanks.
Oh, I'll also be running the Boost-A-Pump. Looking to support 600RWHP for now...more in the future possibly.
Thanks.
The pump and tank are plug and play. They use the same wires as the stock pump. If you are going over 600rwhp I would suggest fuel rails.
Thanks....I found out that on the 99's I may have to splice into the 3-wire harness.....otherwise, plug and play.
Should be around 570RWHP or so. I have the BAP already, and there are 03+ Cobra's running over 650 like that. More than I'll ever see most likely.
I doubt (with that much power) that you'll be reusing your previous injectors. You still gonna give me a chance to buy em? I can't up my power at all without a minor fuel system upgrade...
Actually, gonna reuse the injectors and MAF. Lid is confident they will be fine up to the power levels I'll be pushing. I've also researched and found numerous 03+ Cobra's pushing over 600RWHP on their stock injectors, MAF and fuel pumps, just adding the BAP for more fuel.
If I have to go up to 55 lb'ers, I'll definitely let you know and give you a good deal on them!
You want the pump? Super cheap for you!!! :nice:
yes. PM me at [email protected]. that's the account i'm using nowadays...
