Need Some help... I'm Overheating
  • Thread starter Thread starter Shocwave04
  • Start date Start date Dec 15, 2004
Shocwave04
78
Austin (from Dallas)
Dec 15, 2004
  • Dec 15, 2004
Ok heres the deal my stang has been having a funny problem. Whenever I'm driving it the temp gauge is going up and down without any change in RPMs. It I know its not a gauge probmlem cause the engine was actually overheating. My first thought was that it was the thermostat B/C I have plenty of coolant and its 50 deg outside. But I just replaced the thermostat about 4 months ago? Is this whats going on or could it be something else like a leak or something. (It looks to me like I'm not loosing any coolant). She overheated so bad today that I barley made it home.
Any help would be great ASAP.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Dec 15, 2004
  • Dec 15, 2004
Do you have a clutch fan; if so it could be bad. If your sure your not losing coolant then you can pretty much rule out the water pump or blown head gasket. It could be the thermostat. You should flush your cooling system when you change it to eliminate any trash that might be clogging the system somewhere.
Shocwave04
78
Dec 15, 2004
  • Dec 15, 2004
Re
Is it possible that I could have put to much anti freeze in the system? Maybe that could be clogging it. Making the pump work to hard
Shocwave04
78
Dec 15, 2004
  • Dec 15, 2004
Re
It finally cooled down enough for me to check the radiator and I had lost a lot of coolant, but it could have been just from the spray and steam from overheating
M
mustangdave
2,976
North Carolina
Dec 15, 2004
  • Dec 15, 2004
Water pumps have a weep hole on the bottom; usually when it goes bad, water will leak from there. Fill it up with water, run it and check for a leak there.
snowball
44
Melbourne, Australia
Dec 15, 2004
  • Dec 15, 2004
Need Some help....I'm overheating
If the temperature is only 50 degrees you should not be overheating. When was the last time your radiator was flushed? It's quite likely the coolant is not flowing into the engine properly when the thermostat opens.
J
jesserose17
219
Southern CA
Dec 15, 2004
  • Dec 15, 2004
To make sure your head gasket isn't blown, check your oil dipstick for traces of coolant/water. Also, other way to check, let engine cool down, with cap off, fill up the raditor and then run and let it warm... watch for bubbles in the raditor which could also incidate blown gasket.
Shocwave04
78
Dec 15, 2004
  • Dec 15, 2004
Re
Ok I filled the radiator back up with water, went and ate, and came back home, when I got home the temp gauge was back to normal but when I looked under the hood a lot of steam was shooting from around the top part of the radiator, I can't really see where its coming from, but I'm pretty sure its a leak now. Could it be possible that steam is coming out of the top of the radiator without the leak being there??
This is pisses me off
67GTA-FB429
777
Tri-Cities, Wa
Dec 15, 2004
  • Dec 15, 2004
Your radiator is shot. You might be able to get it patched if you ahve a radiator shop. But I would buy a new one. It is only venting steam because it only leaks from the top when it is warmed up.
The reason your gauge is all of the place is that you are low on coolant.
J
jesserose17
219
Southern CA
Dec 15, 2004
#10
  • Dec 15, 2004
  • #10
Are you sure that the radiator cap isn't faulty?
67GTA-FB429
777
Tri-Cities, Wa
Dec 15, 2004
#11
  • Dec 15, 2004
  • #11
Might be, it is an easy replacement. Getting your radiator tested is as easy as pulling it too. And if it is an older radiator you would be advised to test it.
Shocwave04
78
Dec 15, 2004
#12
  • Dec 15, 2004
  • #12
hmm thanks for all the tips i had this one referbished not to long ago so I might take it back over there to see what the deal is
A
Overheating!
  • ashleyg
  • Aug 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 9, 2026
limp
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
