need some help with these roller rockers
  • Thread starter Thread starter woodyy24
  • Start date Start date Jun 7, 2005
First Prev 2 of 2
8950HO
658
#21
  • Jun 17, 2005
  • #21
woodyy24 said:
i have a high flow oil pump and my psi is always really high. i took it around the block and it only seemed to get louder. i may end up just putting the stock ones back on.
Around the block???how long does that take?be patient,it takes time,they won`t pump up and become quiet right away.
Mine were loud too at first,(clackitty,clack big time).If they are set up with the correct preload they will quiet down.Let it run.
woodyy24
290
illinois
Jun 17, 2005
#22
  • Jun 17, 2005
  • #22
alright. think i will let it run for a while tomorrow and see what happens. maybe get a vid/sound clip so you can hear what it sounds like.
V
v8only
2,378
22
49
Jun 17, 2005
#23
  • Jun 17, 2005
  • #23
roller rockers are noticeable at idle, maybe while accelerating. they make a very specific sound. I like it. I wouldn't consider it "loud" though.
8950HO
658
#24
  • Jun 17, 2005
  • #24
In my case the Crane 1.7 roller rockers were MUCH more quieter in operation,(after the lifters pumped up),and still are... compared to the junk 1.6 stock Ford rockers they replaced.
Properly operating roller rockers make a... "sewing machine", type of precision mechanical noise which is on the quiet side.
J
jerryD
1,061
Gladstone, MO
Jun 18, 2005
#25
  • Jun 18, 2005
  • #25
the lifters will be pumped in in about 15 seconds. if you got oil pressure, they're pumped up. some rockers make more noise than others. mine make a sound , a little at idle but get a little noisier as the rpms go up.
woodyy24
290
illinois
Jun 18, 2005
#26
  • Jun 18, 2005
  • #26
here it is. has a nice tick to it even after 10 minutes of running.
i kinda touched the coil a little
Click here to watch 000_0755
J
jerryD
1,061
Gladstone, MO
Jun 18, 2005
#27
  • Jun 18, 2005
  • #27
i think that sounds fine. heck, i think it is quieter than mine. IMO you have nothing to worry about.
txstang84
1,639
42
69
Tuscola, tx
Jun 18, 2005
#28
  • Jun 18, 2005
  • #28
the lifters "should" be pumped up in about 15 seconds, but that's not always the case, after resetting the lash on my friends cobra (AFR 185's with Comp pro magnum rockers) it took more than 15 seconds...more like 2 or 3 minutes. and yes, he does carry excellent oil pressure...every engine is different. some make a mild cacophony, much like a sewing machine like 8950HO mentioned. I run comp magnum roller tip ball stud rockers, and they make a little noise, but not obnoxious...but the majority of my experience is with fully adjustable rockers, not pedestal mount.
at any rate, as long as the preload is between 0.020"-0.060", the rocker geometry is correct, and there's no other interference, they should quiet down
First Prev 2 of 2
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
A
Valvetrain help
  • Angelq1028
  • Dec 20, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2024
limp
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
