Need some help
  • Thread starter Thread starter kornnutt
  • Start date Start date Dec 30, 2006
K
kornnutt
14
Washington
Dec 30, 2006
  • Dec 30, 2006
Ok was having a problem with my car overheating and water coming out the exhaust. So was told to tear it down and check head , gaskets all the stuff that could be wrong. Pulled the right head today all the bolts in the valve tran came out with clean threads except the one between the third and fouth piston. The threads had looked to have buit up burnt oil and smelled like gas. The bolts on the on the lower the fisrt 2 had water coming out the bolt holes and the others where fine. I am a newbie when comes to tear down a engine and ford engines. I know when one is blown but I still had good oil pressure. Should I just invest in a new block. Thanks for the help.
71swing
199
Omaha,NE
Dec 31, 2006
  • Dec 31, 2006
water coming out of the lower bolt hole is normal, The lower bolts bolt into the water ports. Just make shure when you re-install that you put some sealer on the threads.
just clean her all up and re-install heads with felpro graphite heads gaskets part number #1152. 25$ each.
how did the lower intake gasket look, it too could have been the source of the problem.
P.S. when intalling the intake bolts never torque higher than 18ft. lbs. If you go higher they can work against the head bolt, causing future head gasket failure.
K
kornnutt
14
Washington
Dec 31, 2006
  • Dec 31, 2006
What about bolt that has oil on it is that something to worry about?
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
MadSquirrelTech
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
