I was about to call this guy an idiot until I read this:
March 2003
After several measurements and trial installations. I could not fit the Tremec into my 65 Mustang without altering the transmission tunnel. At this point I had to decide how I was going to take on the task. I have never done sheet metal work and didn't even know where to start! So I jumped in head first and cut out the floor.
He's installing this into a 65 mustang, not a fox body.
it's plug and play with the fox's, the only mod you've got to do to the cars is to cut the spot welds off the stock crossmember, very simple.
the tko's are easy too, you just have to put a different yoke onto your driveshaft end, and use a different clutch disc.
Putting a tremec into a mustang honestly is no more work than doing a straight up clutch job on a t5.
email me at
[email protected] if you want to talk about it.
