need to know if my stock header bolts will fit my new headers?
Well
The main thing you want to ensure is .......
the correct length of the bolt :D
Too short and you might strip some threads in the heads :notnice:
Too long and you will bottom out the bolt thus not clamp properly :notnice:
Stick a small phillips screwdriver in the hole to measure the depth of the
hole. Also consider the thickness of the header flange, header gasket,
and if you use a lock washer.
The objective is to get a bolt that takes up as many of the head threads
as possible while not bottoming out ;)
Grady
