Need wiring to install an alarm
Blackened302
1,439
South TX
being that my local audio/security place's prices are :Total-CP: , i'm gonna buy the alarm online for $100 cheaper than the :bs: they're charging me. granted, installation is included in their price, i don' think $100 is worth an installation :Damnit: .
i don't have a haynes (i know i need to get one...) so i was hoping one of you fine gents would give me the locations and colors of the door triggers and power door lock circuit for keyless entry, and also the dome light and parking light circuits.
any other help/tips would be greatly appreciated. thanks, guys :nice: .
it goes: wire/color/polarity/location
12volts yellow + steering column
Starter white/pink + steering column
Ignition tan/white + steering column
Accessory gray/yellow + steering column
Second Accessory black/green + steering column
Power Lock pink/yellow either kick harness to rear
Power Unlock pink/green either kick harness to rear
Parking Lights+ brown below drivers kick
Door Trigger blk/blue or gray + below drivers kick
Trunk/Hatch Pin black/pink + at trunk sw. or light
Trunk/Hatch Release purple/yellow + below drivers kick
Factory Alarm Disarm dark green/purple - either door harness
Tachometer gry/orn or dk. grn AC EDIS module
Brake Wire red/lt.green + brake switch
Horn Trigger yellow - right of st. column
MAKE : FORD | MODEL : MUSTANG | YEAR : 1994
* The logo is registered trade mark of Ford Corporate.
I hope you are familiar with the 5 wire door lock system because most fords use it, good luck.
If you have factory keyless, it kinda makes the lock hook-up simpler. A DEI 451M makes it snappy and cleaner IMHO (a couple SPDT's work just fine too).
Good luck.
eeerrr, DEI 451M? SPDT's? no clue as to whatyou're talking about, hissin.
oh, and i don't have the factory anything, at least i don't think. is there a way to check? all i was given when i bought the car was the ignition key and the other for teh doors, no remotes whatsoever.
