Neutral safety switch(the one on the trans not clutch pedal)
productj1
42
I know theres a ton of threads about this but I searched and didn't find the answer i'm looking for. I'm doin the aod to t-5 swap and am wondering how I am going to get the reverse lights to work but bypass the switch that is used on the aod but not the t-5. I don't need help with the one on the clutch pedal. I have that bypassed. So I was also wondering if I can make it start only in neutral without the switch on the clutch pedal so ther are no accidents.
thanks,
Jeff
The neutral safety switch on the 5 speed trans has nothing to do with the starter circuit. It is to make sure that the trans is in neutral when the engine running codes are dumped.
Diagram courtesy of Tmoss & Stang&2birds?
Starter circuit wiring:
attachment.php
