New 351 Combo and Est Help Needed!
  • Thread starter Thread starter Hickfied
  • Start date Start date Jul 22, 2006
Hickfied
413
Morganton, NC
Jul 22, 2006
  • Jul 22, 2006
Well, this comming friday I will be getting a 357... I pretty much have my mind made up with most of the parts I am using, but suggestions are needed also!
1969 Mach1 block
turned stock crank
forged rods
forged pistons
10.5:1 CR
Stock 69 heads, ported, 2.02 valves
unknown cam, 288 ad. duration, .49x lift
Typhoon intake
fuel rails (any suggestions?)
30# injectors
255 fuel pump
fuel regulator (suggestions?)
braided line (size suggestion?)
BBK CAI
MAF (size and brand suggestion?)
Accufab TB
BBK swap headers
BBK H pipe
Spintech muffs
MSD Dizzy and coil
FRPP Wires
NGK plugs (What heat range?)
The big question I have, is about Nitrous. I want to run a wet system around the 200 shot level, if the block can take it. I have never messed with nitrous, so I don't know anything about it, I had been researching turbos because that is what I wanted to do, but with my CR, I no longer am thinking about the turbo.
I know I need a MSD window switch, and I need something that will retard the timming when I am spraying. Anyone know of a kit that will suit my needs? I also will need a bottle holder, and a bottle opener.
One last Q, how much HP would y'all estimate this setup making, with and without the nitrous?
89Notch
1,669
MSU
Jul 22, 2006
  • Jul 22, 2006
stock heads? booo
Hickfied
413
Morganton, NC
Jul 23, 2006
  • Jul 23, 2006
Just for a few months... Going with AFR 185's when I can.
Woodrow
183
Atlanta/Auburn
Jul 23, 2006
  • Jul 23, 2006
Why the small intake and cam, your not building a 302...
Hickfied
413
Morganton, NC
Jul 23, 2006
  • Jul 23, 2006
The cam is already in the engine... And the intake is $330 shipped compared to a $600 intake... What would be a good intake?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jul 23, 2006
  • Jul 23, 2006
as for your question about timing retard get yourself a msd digital 6 ignition box. It has 2 rev limitors and a timing retard. Works great for my nitrous set up.
As for braided lines i went with push loc type of fuel line. It was cheaper and NHRA approved. At the time only the blue color was approved.
I really like my XE 274 comp cam. Works very well with my nitrous and gives me great N/A power. I only have 8.2 to 1 compression. I need more.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
I need help with an 06
  • boviske underwood
  • Oct 30, 2025
  • Services - Tuning, Welding, Mechanic, Body Work...
Services - Tuning, Welding, Mechanic, Body Work... Oct 30, 2025
boviske underwood
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
