New alternator makes less power than original one.
Bmr4life
161
ATL
I installed a 3G alt in my stang and followed the directions to a T. I notice now that my mustang almost dies sometimes when sitting at idle with the heater fans blowing and head lights on. is there a way to mount 2 alternators under the hood? I have a stereo to put in and this current problem will only get worse. thanks
theres something wrong. Even with the stock alternator, headlights on, heater on high, and stereo blasting, you should have 'enough' juice. My lights would slightly dim though when the bass hit... but nothing like what you describe.
Double check your wiring, and make sure the contacts for the power wire to the 3G are clean, the wire is good, and the contact to the drivers side electical stuff is good.
Are you sure the 3G is good?
