Ive seen the "Auto Meter Mustang Instrument Cluster" and the "Roush Performance Mustang Performance Series Clusters" and I think they look sweet. Is there anything like them made for our years? I'd really like to get one like that. Thanks.
tjh566 said:Ive seen the "Auto Meter Mustang Instrument Cluster" and the "Roush Performance Mustang Performance Series Clusters" and I think they look sweet. Is there anything like them made for our years? I'd really like to get one like that. Thanks.
florida50.com they are amazing quality!!18mustangs said:A couple of years ago in 5.0 mustang I saw a small ad from a florida company (forgot the name) that stated they made the clusters for 94\95, but it was like $500.
Tim
ef200098 said:i looked into doing this but how do you keep your stock chit, like the odometer and trip? you would have to replace all of your stock senders. speedo, oil pressure water. etc. then the computer gets screwd if the sender sends the wrong voltage to the EEC
NOpe, there are two water guages, the ECT sensor which sends readings to the EEC and then the Water temp sending unit that sends water temp to your gauge un connected. As are the batter voltage on sends to the cluster and one sends to the EEC so you can remove all of those gauges and nothing will happen to your car.ef200098 said:computere does get signal from water temp and volts. computer adjusts injector pulse width and timing if there is a variance in voltage. computer also uses water temp to adjust timing, also for cold starting vs hot starting. computer also uses the speedo for the dashpot decay (rate at which the idle will be brought back down). why get an autometer speedo if everything else is going to be stock?
