New Heads or Supercharge the 383?
  • Thread starter Thread starter 95Vert383AOD
  • Start date Start date Jun 12, 2009
  • 3
First Prev 2 of 3 Next Last
95Vert383AOD
1,133
34
69
New Bedford, MA
Jun 15, 2009
#21
  • Jun 15, 2009
  • #21
Stopsign32v said:
You find a 383W, with his heads, his intake, and his cam. We will wait....
Yeah believe it or not ive been reading Chevy sites to see what those guys run on their 383 strokers. Its helping. But theres not much 383 Windsor documentation. Easier to find 393. My 383 uses a longer rod...Chevy 6.2 So the Motor should be an awesome revver. The 383 is like the 351 version of a 331.
Pokageek
2,767
MA, USA
Jun 16, 2009
#22
  • Jun 16, 2009
  • #22
Not to get too far off topic but how does that work? Longer rod gives you less compression "space" i.e. c.i. than a 393..? .. at least, I am trying to visualize it.. So to get more c.i. you go to a shorter rod? But wouldn't a longer rod mean longer to revv?? .. eh ..er .. shorter rod quicker rev..Sounds contradictory but I am sure there is some scientific methodology there. I dunno.. I just start it and it runs.
95Vert383AOD
1,133
34
69
New Bedford, MA
Jun 16, 2009
#23
  • Jun 16, 2009
  • #23
Because the Crank is 3.75
Pokageek
2,767
MA, USA
Jun 16, 2009
#24
  • Jun 16, 2009
  • #24
Sry man I still not sure how the concept works tho. I will look it up.
95Vert383AOD
1,133
34
69
New Bedford, MA
Jun 16, 2009
#25
  • Jun 16, 2009
  • #25
Yeah...smaller crank longer rod. Not sure how it works. I heard it has a near perfect rod ratio. I'm no machinist though.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 16, 2009
#26
  • Jun 16, 2009
  • #26
Can you not read ???
I said to look for something close to what he wanted to do
I'm done with this thread :Word:
Sorry Chris ... Sometimes one can keep quiet for only so long
but
As I said above ... I'll not reply any more and side track your thread
Grady
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jun 16, 2009
#27
  • Jun 16, 2009
  • #27
The rod length doesn't really effect compression at all. All that is adjusted with the wrist pin height. All it does is change the rod/stroke ratio, which helps with piston side load. It doesn't really effect the revs either.
Kurt
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jun 16, 2009
#28
  • Jun 16, 2009
  • #28
The displacement is really not that critical. All the stroke really does is adjust the rpm at which the engine makes max torque and power. IE, a 383 is going to make 400rwhp at 5600rpms whereas a 408 wold make 403rwhp at 5400 rpms. My point is, you can look at your head and cam combinations on 408 engines and so forth, and get a pretty good idea what you can adjust on your engine. Looking at a Ford 408 combination is going to be a lot more helpful than looking at a Chevy 383.
Kurt
Pokageek
2,767
MA, USA
Jun 16, 2009
#29
  • Jun 16, 2009
  • #29
I agree. 408 is going to be your best bet for combo comparison. You can look at mine but between the cubes and the compression , we are a bit off. Whats your goal really?
Thinking about it more.., with your comp ratio,,..hmm...If it we ME.. I would go forced induction on 2nd thought. Why? Because my educated guess could be way off and Stopsign brought it home with the comment - you may only get to 400rwhp NA. Now that's not bad at all, but ME, I would try to get more out of it. I would go for it! You could end up pushing more rwhp than you would ever have NA AND a nice smooth running car. I am going to have to back down to prolly 430rwhp to get that out of my NA man.
Black Stampede
1,811
Grand Rapids, MI
Jun 17, 2009
#30
  • Jun 17, 2009
  • #30
It just comes back to the idea that ideally its good to be making the correct power for your combo before you throw boost at it just so you arent bandaiding frustratingly low dyno numbers.
Question. Maybe I missed this, but has it been verified if his low numbers are due to a problem with the build or is it just the fact that the combo isn't very ideal?
Pokageek
2,767
MA, USA
Jun 17, 2009
#31
  • Jun 17, 2009
  • #31
No it hasn't. However, with the pro-comps, typoon intake and 351R headers my 414 only put out 338rwhp lol. So take away 31 c.i. and down the compression to 9:1, and 200 something rwhp is right there. Amazing but sheesh, if you dont let it breathe it doesn't matter what size engine you have.
Black Stampede
1,811
Grand Rapids, MI
Jun 17, 2009
#32
  • Jun 17, 2009
  • #32
So with that being said, the combo itself is making what it should, correct? If that is the case I really don't think going the blower route is that bad of an idea. I think its going to come down to your personal preference. Do you want a big HP all motor car or a blown car? It's going to make great power either way.
Pokageek
2,767
MA, USA
Jun 17, 2009
#33
  • Jun 17, 2009
  • #33
The combo basically sucks in terms of optimizing HP. (I think 383 is aware of that now). However, with a new cam, the pro-comps may work ok with FI. But I dont know anyone with FI thru pro-comps.
Oh Yea...opcorn:
Black95GTS
1,644
Marlborough, MA
Jun 17, 2009
#34
  • Jun 17, 2009
  • #34
There is no such thing as too much head.
Think about it.
Adam
Black Stampede
1,811
Grand Rapids, MI
Jun 17, 2009
#35
  • Jun 17, 2009
  • #35
Think about it.
Adam
:Teh-Win:
95Vert383AOD
1,133
34
69
New Bedford, MA
Jun 17, 2009
#36
  • Jun 17, 2009
  • #36
yeah my cam is mild...compression is mild and the heads suck at flowing.
Stopsign32v
394
Gville, SC
Jun 17, 2009
#37
  • Jun 17, 2009
  • #37
So get a cam that is designed for your combination and goals in mind and get a good set of heads. I'd suggest Trickflow High ports or some AFR 225s. Your compression isn't that bad at all.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jun 17, 2009
#38
  • Jun 17, 2009
  • #38
+1 on the High Ports. If you can squeeze the change go for the Trick Wedge Rs.
Kurt
95Vert383AOD
1,133
34
69
New Bedford, MA
Jun 20, 2009
#39
  • Jun 20, 2009
  • #39
I want a head with inline valves in stock locations. Any links to trickflows that can do this??? I enjoy the quietness of my shaft rockers.
Stopsign32v
394
Gville, SC
Jun 20, 2009
#40
  • Jun 20, 2009
  • #40
AFR 225s with LSX style springs and Ti retainers
  • 3
Fox 329 HP low for a stroker?
  • Andresquintana.mma
  • Apr 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2025
Jarhead67
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
