Nope, not kidding. The car seems to run alot smoother, and sounds smoother with my Mac exhaust. If it is an exhaust leak, it would be strange. Since its been rattling, I replaced midpipe and cat-back. so I would have had to create the same type of exhaust leak in my installation as what was in the factory set-up. If its the manifolds on the heads, you would think they would have had to drop the manifolds to swap heads this past weak, and would have tightened any leaks.
Doubt its detonation just cuz it does it in neutral with no load, and generally at a specific rpm...typically 2.4 or 2.5k...and I can hold it at that rpm and it'll rattle all day long.
Could easily be something else loose. My thinking has been, its under warranty, let Ford fix it. So far I've gotten new heads out of the deal. Wonder whats next?!?
The shops have been Ford dealers. So far this is my second dealer to work on it. The first swore it was a cat convertor, and had me waiting 3 months on a back-ordered part, finally I put aftermarket exhaust on it and it still rattled, didn't bother taking it back to that dealer. This dealer, I could understand them thinking it might be the valve guide TSB problem and Ford ok'd the new heads after them describing the problem.
Anyways, my guess it is just something loose and rattling at this point. Not sure what else it could possibly be....except for the shield on the tranny where the clutch cable enters...maybe I'll check that. Either way, I'm getting a bit tired of this car and Ford dealers, especially when they won't give me a loaner car when mine's stuck at the shop for a week.
