new mods need help
90sting
193
laf la.
this is my mods now i need to see
what you'll think
i will ran with new mods.
times with old mods my best so for is 14.09 @ 96mph
old mods
26x10.50x15 et streets
other mods r
1 5/8 shorty headers 'hookers'
1.7 roller rockers
hot coil
abv timing
short belt no p/pump
aftermarket fuel pump not sure what size?
sub frame con.
90/10 front shocks
50/50 rear shocks
after market lower con arms
cold air kit 'bbk'
i think thats about it
new mods
typhoon intake
alum heads afr 165 or 185 not sure yet
throttle body 70mm "bbk'
'b' cam
please let me know what you think.
90sting said:
thanks anyone else?
no one fells like talking today or this a bad combo?
lol
Yeah I know what you mean....usually these type threads are feeled with opinions....I guess I'll start...ha ha
Like I said in another post....If money isn't to much of an issue....I would get custom cam, stick with AFR heads and get them stud mounted if you have enough money to cough up for some new stud rockers, 65mm throttle body is good up to bout 400 horsepower (accufab is probably best quality piece), probably a nice edelbrock performer rpm intake would be a nice addition to....
Either 24lb or 30 lb injectors would be fine for that combo....
A lot of things depend on the budget as you know I'm sure...
You should have a solid 300rwhp and then you can see low 12's with traction all day long :nice:
I like everything you mentioned except the b-cam. You should go with a custom, and if money is a concern you could go with the split duration Trickflow stage 1 or maybe 2. And a bigger mass air meter is a must with a combo like that I'd with with atleast a 73mm C&L there pretty cheap on ebay.
