new parts: car wont start
blackfiveoh
I have a 1991 GT and just added 93 Cobra heads with factory roller rockers, cobra intake, e303 cam, 65mm throttle body, and equal lenth headers.
Problem: the car will not start, it seems to not have much compression in the cylinders like the valves arn't staying open long enough. its like they are opening before the compression stroke is finished. Im using the pushrods that cam with my 5.0 not the cobra could they be a different lenth? Are the factory cobra roller rockers the 1.5's or 1.6? what else could possibly cause this?
thanks for the help
thanks for the help
Wow!! Not sure about the push rods! But they use the 1.6 RR's.
Do a compression test to verify good compression.
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading.Your local auto parts store may have a compression tester to rent. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
Poor results on the compression test -adjust the valves.
Valve adjustment procedure from the Comp Cams website:
Intake valves:
Following this procedure, carefully adjust all intake valves. Turn the engine over by hand in the direction of its running rotation until the exhaust pushrod begins to move upward to open the valve. This ensures that the intake valve lifter is on the base circle, and the intake valve is ready to be adjusted. Tighten the adjusting nut until all the slack is taken out of the rocker arm and pushrod. By lightly turning the pushrod with your fingers as you tighten the adjusting nut, you will discover or feel a point at which there will be slight resistance. At this point, you have taken all the excess slack out of the pushrod. You are now at what we refer to as zero lash. Turn the adjusting one-half turn more. This will give you the ideal pre-load of the rocker arm, pushrod, and lifter.
Exhaust valves:
To adjust exhaust valves, turn the engine over until the intake pushrod moves all the way up. Rotate past maximum lift, approximately one-half to two-thirds of the way back down. The exhaust valve lifter is now on the base circle and the exhaust valve can be adjusted. Rotate the exhaust pushrod with your fingers and begin to tighten the exhaust adjusting nut. When you feel the resistance on the pushrod, you are at zero lash. Tighten the adjusting nut one-half turn more. Go through the exhaust valves and repeat the procedure carefully. Now all of the valves are adjusted with the proper pre-load.
Compression test OK - then do the Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 30-Jul-2006 to include 94-95 specific information
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 3A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Intake valves:
Exhaust valves:
B.) Coil
C.) TFI module
H.) Computer
B.) Distributor cap
C.) Rotor
Two reasons:
attachment.php
You da man for wiring diagrams...
