New Project Car - The Civil War Mustang
TTSaleen
191
180
53
NC
Picked this car up July 23, 2026.
Had a long history of bracket racing in Holcomb Civil War Shootouts (hence the name) and Fun Ford Weekend.
408" stroker engine in an old-school SVO A351 block
Steel crank, H-beam rods, JE pistons, Comp XR292-R10 solid roller cam.
C4 transmission and 4.10 gears.
Weight is 2800 lbs.
Here's the full video of my journey so far (getting car and taking it apart).
It's an old school Ford Motorsport SVO block, part number A351. Bored .030" over with JE pistons (-22cc dish) putting out 10.0-1 compression with a new Eagle forged steel crank (zero/internal balance), with H-beam rods.
Has old school Canfield heads (previously ported by Fox Lake Racing) that I just had new stainless valves put in (size 2.055 and 1.60).
Comp Cams Xtreme Energy XR292 R-10 solid roller cam (3,200 to 7,200rpm range, with 254/260 @ .050 and 0.621/0.627 lift).
It should make good power as the previous owner bracket raced it and went consistent 6.50's in the 1/8th mile.
The PO ran nitrous on it a few times, but mostly he ran it naturally aspirated (bracket racer stuff).
I on the other hand like to build my projects to be high horsepower dyno cars that can goto the track and lay down a fast pass.
In this case, I have decided to ditch the C4 transmission and put a TKX in the car.
I may run the nitrous at first to see what it makes, but ultimately I'd like to make this a twin turbo setup.
Ryan
Reactions: gkomo
Got the rearend rebuilt -
Moser 5 lug axles in 33 spline
Moser 9" ends for axle retention
SN95 rear disc brake kit
Installed my 16x10 Bogart RT wheels and Hoosier 28x10 slicks on it.
With the Bogart Force 5 front wheels and M+H tires, it is starting to look more of my style now.
Also took the time to paint underhood factory Vermillion Red.
Won't be long and I'll have the motor dropped in.
Lots of updates in Episode 2.
Rearend updated with 5 lug axles, 9" ends, disc brake conversion
Motor rebuilt with new crankshaft, intake/exhaust valves, oil pump, rings, bearings
Master cylinder replaced (Cobra) and new brake lines
Disassembled interior and trunk
Installed Moroso battery box
New tires and installed my Bogart wheels on the rear
Reactions: gkomo
I meant to say something g about the t-star housing leak. It looks like an aftermarket one like you would get from a parts store. If so I had the same issue and it was the housing face not being flat. I got it flat by spray glueing some wet dry sandpaper to a piece of 1/2” glass off the table on out back porch. Used some 200, 320, and finished it with 600. Haven’t leaked a drop in 10+ years.
Motor sounds spicy! Hard to beat an old school 3” exhaust with dumps.
Reactions: TTSaleen
