*New Purchases* + Questions and Opinions welcome!
looking great Chris.
Patience pays off, you obviously have it. Best of luck to your build. I sign on but don't read the boards as much so shoot me a PM when things come together.
I have had a lot of friends have bad experiences with MMR. Especially the oil pumps blowing up! I would be careful and double check everything if I were you!
Also, I think you will have a hard time with that fuel pick up. (Looks like an old Mallory unit) With the stock tank you might have fuel slosh and suck up air. I would look into the Glens Sleeper Tank if I were you.
Good luck with your set up. :nice:
Double check what? They bored the block, balanced the rotating assembly, supplied me with their sidebolts, and some Manley piston rings and some main bearings. Not exactly sure what I can check about any of that.
I'm not running an MMR oil pump.
The fuel insert should be fine, it's no sleeper or sumped tank but I know a pair of people running them with serious set-ups and no problem. Plus i see a bunch of people online use them with no problems. It's basically the insert MMR sells just used. Sloshing is to worry at the track or if I road raced which I don't, but im not going to do any serious periods of full throttle or go to the track without more than a 1/4 tank anyways.
Electric fuel pressure:
Have some more actual fun stuff that i'm compiling and will post up when i have it together.
Whats a "srinlkler"? :scratch:
EDIT: Love the sound of that thing! :drool: You have 4.10s right? Are you gonna add a tach or switch out the cluster?
