I first ran my car will the following mods: C&L x-cal2 can tune and 4.10 gears. The result will the factory tires at 22 psi was 13.6 @ 103, 60 was 1.99.
I ran last night with the mods in sig and got 13.8 @ 105.1, I don't remember my 60ft. I spun all the way through 1st and 2nd gear both times last night. I even launched easy on the second run and still had really bad traction. I mean I was goosing the throttle through 1st and second gear. All times were at Speedworld (A.K.A Spinworld) in Orlando. People that have ran at the track know exactly how bad the traction is here. If you don't have a good set of tires or drags then you shouldn't run. Since I don't have the money to purchase a good set of tires or a set of drag radials. I would like to here all suggestions on what I can do about the traction issue. Also to the people who have or still run on the factory p.o.s tires, what pressures do you recommend running them at?
I knkow that the car should run a low 13 or a high 12, I am in desperate need of some traction, or just take the car to the track in Tampa.
Thanks
Thanks
