Next mod?
  • Thread starter Thread starter CManT1914
  • Start date Start date Dec 4, 2004
1 of 2 Next Last
CManT1914
3,172
Killeen, Texas
Dec 4, 2004
  • Dec 4, 2004
I think I've ran out of bolt-ons. What can I do next for more power short of power adders or heads? I don't have the money for a supercharger or heads, and I don't want to run nitrous. The only suspension I might do are some rear control arms. What are everybody's ideas?
jb89coupe
416
CT
Dec 5, 2004
  • Dec 5, 2004
1.7 rockers, windage tray, alum flywheel, alum driveshaft, tubular control arms, weight reductions, etc...
jb89coupe
416
CT
Dec 5, 2004
  • Dec 5, 2004
longtube headers, mac prochamber...
Funanin
356
Horsham, Pennsylvania
Dec 5, 2004
  • Dec 5, 2004
BRAKES!!! ...or perhaps an AFM N/A Powerpipe to replace ur MAC CAI? With a twEECer maybe? Also dont forget to put an AFPR on there to keep ur A/F ratio in check. A good tune is good news when u breakin em loose.
If you have a cowl hood u can put a 1" phonelic spacer between ur manifolds, if not u can go with the 3/8". Either one will add a little here or there.
J
jerry beach
2,671
Ocala,FL
Dec 5, 2004
  • Dec 5, 2004
Are you running auto or stick? You really need heads and cam to compliment the big MAF. I dont understand a MAF upgrade without a supporting cast, did it help? You are spinning real bad right? Check your trac lock, is it working? Gears may do you good, but it depends IMO.
Blakthorn
299
US
Dec 5, 2004
  • Dec 5, 2004
shoula spent all that $$ on a blower!
fiveoboy02
17
  • Dec 5, 2004
Control arms are a good choice. You will see better traction and handling. Finding ways to remove weight are free and can only make you faster in most cases.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 5, 2004
  • Dec 5, 2004
Brakes
PNY PWR
522
Wichita, KS
Dec 5, 2004
  • Dec 5, 2004
I agree, I never believed it till I slapped on the MM lowers. The car has a completely different pull now.
CManT1914
3,172
Killeen, Texas
Dec 5, 2004
#10
  • Dec 5, 2004
  • #10
Thanks for the replies. I have a 5 spd, and already have gears and exhaust work done (except for headers). As for that CAI, I actually have it taken off right now, I'm having problems mating it with my MAF. They don't work together. I have a 1" spacer, but it's just sitting around because I don't have enough deck clearance. I really want more power, I don't have a huge traction issue, not enough to warrant much suspension. So how much will the 1.7 rockers help with stock heads? How much will the AFPR and a tune help? And what is a windage tray? I never heard of it before.
Funanin
356
Dec 5, 2004
#11
  • Dec 5, 2004
  • #11
sell the 1" spacer to a buddy with a cowl hood, and pick up a 3/8" one, that should fit. The 1.7 rr should add about 10-15 fwhp because they are rollers and not the crap tappet (reduce a ****load of friction, which = more hp) The AFPR with a twEECer will probably be able to squeeze another 15-20 fwhp out of your setup if not more. As long as it hasnt already been tuned.
Funanin
356
Dec 5, 2004
#12
  • Dec 5, 2004
  • #12
also if u have a 5speed an aluminum driveshaft will help u shift alot smoother because of the reduced spinning weight (inertia) the trans has to deal with when engaging and disengaging the clutch. Also drops a few lbs off ur weight.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 5, 2004
#13
  • Dec 5, 2004
  • #13
I know you said you don't have the money, but I'm going to say you need heads. If you can't fork out enough for AFR's, get some GT40's, Thumpers, base model TFS's or Edelbrocks, something. Even if you keep the stock cam, you'll still have a huge gain. I would not be suprised if a set of heads knocked over a second off your quarter mile time. I will say though, that a good set of upper and lower arms would make a huge difference in handling and launch.
M
mackey
1,284
Beverly, Massachusetts
Dec 5, 2004
#14
  • Dec 5, 2004
  • #14
Just wondering why you do not want to run nitrous in the car?
Funanin
356
Dec 5, 2004
#15
  • Dec 5, 2004
  • #15
I agree with 90-GT, heads is ur best bet. Just save up a while. you will be happier in the end.
jb89coupe
416
CT
Dec 5, 2004
#16
  • Dec 5, 2004
  • #16
A windage tray is a shelf that sits in the oil pan, keeps oil from splashing up on the crank and gains you a few horsepower. All the stuff I listed and that has come up on this thread are good small gains and will make a difference collectively. My advice is do as much of is as you can at once or you won't notice it and may get frustrated ("this isn't working"). But 5 horsepower here, 10 pounds there, it all adds up. If you add 20 horses and knock 100 pounds off your car all at once it *will* feel significantly quicker. But if you price everything out you'll probably find that heads are going to be a better bang-for-the-buck. Look into having yours ported locally, you can usually find someone who will do it for $200-300, just make sure it's a reputable shop.
CManT1914
3,172
Killeen, Texas
Dec 5, 2004
#17
  • Dec 5, 2004
  • #17
I just don't like nitrous.
Where can I get a twEECer and do I need a laptop to use it?
jb89coupe
416
CT
Dec 5, 2004
#18
  • Dec 5, 2004
  • #18
www.tweecer.com
You can dump $600 on a tweecer (and yes you need a laptop to use it).. maybe squeeze 5-10 horse out of your car, or drop $600 on some heads and pick up 40-50...
fiveoboy02
17
#19
  • Dec 5, 2004
  • #19
You really should consider it. A base kit is under 500 bucks and you WILL get a significant amount of extra power. After all, that is what you want...
Like JB said, you can do little things here and there that will add up, but you're going to pay what you'd dish out for a nitrous system and end up with a comparitively small gain in power and torque.
jb89coupe
416
CT
Dec 5, 2004
#20
  • Dec 5, 2004
  • #20
I agree, nitrous is a blast to have and probably the best $/hp mod in this price range. If you're like me though you want the power there all the time and don't want to keep filling a bottle. I ran a zex kit for about a year, it made driving a whole lot more fun, but I got sick of always running to get more... just me.
1 of 2 Next Last
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
