Nick's "lvndpst" Restoration (and Slight Modification) Thread
  • Thread starter Thread starter 95BlueStallion
  • Start date Start date Nov 27, 2016
  • 59
  • 60
  • 61
  • 62
  • 63
  • 99
First Prev 61 of 99 Next Last
95BlueStallion
My assy trans to myself
5,129
3,100
214
Cedar Rapids, Iowa
Apr 13, 2018
#1,201
  • Apr 13, 2018
  • #1,201
hoopty5.0 said:
That is a big deal. I'm jealous, hopefully I wont be too far behind you. Congrats on getting it running!
Thanks brother. My very first drive with the used clutch was constant bucking and stalling. I was so discouraged and thought the engine was just too radical and was going to need a different cam, etc. Thankfully the PCV fix made all the difference in the world and I didnt go digging into the engine to detune it. Cruising yesterday was awesome. My suspension is shot, the interior needs major cleaning and some replacement pieces, my hatch rattles, and on and on, but all that is easy restoration versus what I have accomplished now. I see the light!
Reactions: Davedacarpainter
hoopty5.0
mechanicus terribilis
7,807
6,960
214
SW Houston
Apr 13, 2018
#1,202
  • Apr 13, 2018
  • #1,202
Just being able to get in and drive it and enjoy it makes all those small issues insignificant.
Reactions: 95BlueStallion
02 281 GT
Agreed...My wife has great Boobs
3,208
1,973
194
Cabot, AR
Apr 13, 2018
#1,203
  • Apr 13, 2018
  • #1,203
I put them on my '95 years ago, and what difference they made. Honestly, I feel like they are the only real option worth doing. They are not any more expensive than others on the market, and are the most robust. Why would buy anything else?
Full-length SFCs make a much more noticeable difference on a Fox than on an SN-95. You'll notice the difference quickly.
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Apr 13, 2018
#1,204
  • Apr 13, 2018
  • #1,204
My stock plastic radiator end cap literally cracked and spewed coolant pulling into my driveway yesterday, so I believe that to be true!
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Apr 13, 2018
#1,205
  • Apr 13, 2018
  • #1,205
I ordered an SVE aluminum radiator, new door and hatch weather stripping, and striker bushings. I am completely missing the bushing on my drivers door, and my hatch rattles like a mofo. The latch gets stuck, so I am going to remove it and soak it like Alan did on his son's car they fixed up. My doors dont sag, just rattle when closed. Im hoping the bushings and weather stripping correct that. I want to cruise and get the clutch broke in so I can feel the 347 up high!
PS, I read quite a few good reviews on the SVE radiator. Anyone here have a bad experience with one?
D
DSB88GT
175
37
38
Apr 13, 2018
#1,206
  • Apr 13, 2018
  • #1,206
When I got my Fox a couple years ago, it had an SVE 3 row. It cooled great, but started leaking a few month's ago. I'm not sure how long it was in the car before I took ownership though. Based on price and reviews, I ended up buying another SVE and so far so good.
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Apr 13, 2018
#1,207
  • Apr 13, 2018
  • #1,207
Thanks. The good reviews have outweighed the bad tremendously so far. I may just dive in and buy my SFCs before I even install it so that its not subjected to my driveway twist.
Mustang5L5
Mod Dude
Feb 18, 2001
43,309
18,021
224
Massachusetts
Apr 13, 2018
#1,208
  • Apr 13, 2018
  • #1,208
Changing out my window guide bushings and readjusting the window tracks really tightened up my doors. They used to rattle when closed but every since I did that door rehab they are really nice and tight.
Now that you have the car driving, you can do all the fun resto type stuff
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Apr 13, 2018
#1,209
  • Apr 13, 2018
  • #1,209
Well, it has a bit to go before I'd say its offically driving, but its close! And yes, I will kinda be jumping around with resto projects as I notice things. I have several bits piled up for interior restoration, but I want to pull the carpet out to clean it and lay down dynamat, so I dont know if I will commit to that until maybe fall. Do it all at once. Stereo included.
I need to finish applying POR15 to the undercarriage first thing, as there is some surface rust I want to tackle. That will be nice to get done forever. But I need to install the SFCs first... So many little things to be able to say I am "finished" with certain aspects of the car.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Apr 14, 2018
#1,210
  • Apr 14, 2018
  • #1,210
I have the sve radiator as well, it seems like it's good quality for the money. I have no complaints.
Reactions: DSB88GT and 95BlueStallion
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Apr 30, 2018
#1,211
  • Apr 30, 2018
  • #1,211
Just to update this, and maybe provide a talking point, I have some good and bad progress to report.
The good:
The SVE radiator is in and works fantastically. No leaks, and holds temp well on an 85 degree day. I put 35 miles on the car yesterday breaking in the clutch.
I also installed new weather stripping on both door jambs and the hatch, as well as new striker bushings. That really tightened up the door, but I can tell my window tracks need a do over, as @Mustang5L5 did.
The bad:
I caved in and bought 3" Flowmaster exhaust tips rather than have a shop custom bend the exhaust I wanted. STUPID.
They dont fit worth a with my used MAC mufflers. Rather than box them up and return them like I should have, I decided to MAKE them work. STUPID.
On the passenger side I had to dent the piss out of the over the axle tube to ensure clearance of the axle and upper control arm. It just barely keeps from rubbing my gas tank tank cover, and thats after I cut off 2" of the pipe where it meets the muffler. I am not wanting to weld it all together, because I would like to be able to remove it to continue my under carriage painting. That means after spending $300 on it, I had to spend $25 more on four 3" clamps, as Flowmaster includes exactly zero clamps to fit the four pieces together, and to the mufflers...
On the driver's side, I had to cut 3" out the flow tube between the muffler and H pipe and weld it back together. That was just to get the clearance to start fitting the over the axle pipe. Its still going to need massaging to clear properly.
Moral of the story, once this is all done I truthfully need to remove my entire exhaust system, check my welds for leaks, grind them pretty and paint the whole thing with high temp paint so that it doesnt all rust apart in a year. Should have just bought a full H Pipe and Cat back versus piecing it all together. I am a RA-TARD.
Also while under the car I found that my transmission output shaft seal is leaking and splattered trans fluid on my new tunnel paint, as well as my pinion seal having a minor leak. Yay!
And no, no pics. Its ugly as fck and not finished. Just a rant.
Reactions: hoopty5.0 and Davedacarpainter
Davedacarpainter
SN Certified Technician
Nov 28, 2015
11,833
11,633
203
Discordia
May 1, 2018
#1,212
  • May 1, 2018
  • #1,212
The pinion seal? That’ll be fun.......
So the new engine feels pretty nice then Nick?
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
May 1, 2018
#1,213
  • May 1, 2018
  • #1,213
It cruises alright, but will randomly buck when in 5th gear around 1500-1600 RPM. Definitely needs a tune, but is drivable as is. I havent been able go full throttle yet, as the first clutch slipped, and I only have 45-50 miles on the new one. Im not about to burn it up! I really wanted to get the exhaust finished last night and put more miles on it, but I didnt come close.
CarMichael Angelo
8,909
234
Birmingham, al
May 1, 2018
#1,214
  • May 1, 2018
  • #1,214
Welcome to the " My tail shaft seal is leaking, and it's all over my newly cleaned trans tunnel" club.
Look at it this way...
It's now way easier to wipe all of the leakage off of all of the new shiny. Be glad you didn't choose bed liner like I did.
Bed liner don't like getting wiped.
Boostedpimp
20+ Year Stangneter
May 8, 2003
1,451
493
154
NJ
May 1, 2018
#1,215
  • May 1, 2018
  • #1,215
The leaking tailshaft helps preserve the trans tunnel and I've never heard of anybody having to make so many modifications to install a set of flowmaster 3" pipes. What kind of mid pipe are you running?
Mustang5L5
Mod Dude
Feb 18, 2001
43,309
18,021
224
Massachusetts
May 1, 2018
#1,216
  • May 1, 2018
  • #1,216
I get a few drips out of my tailshaft after a drive. I should probably top the fluid level off before it gets low enough to cause the famous T-5 whine.
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
May 1, 2018
#1,217
  • May 1, 2018
  • #1,217
It started life as a MAC off road H. I welded in a pair of catalytic convertors that I had from another project though. I was careful to keep the pipes the same length and shape. The issue is that the mufflers I bought are MAC pro dumps. The hangers are welded to the exit of the mufflers. So Ive had to chop them off, grind the welds off, and reweld them back onto the mufflers themselves, just so the flowmaster pipe can fit over the exits of the mufflers. The flowtubes attached to the MACs are too long, and have the mufflers back too close to the axle. And honestly, the 3" flowmaster tubes are huge. Its a tight fit around the axle on the passenger side where you have fuel lines running. Couple it with each side coming in two pieces, and its a wobbly mess while youre trying to position i while laying under the car. I will make them work. I just know my exhaust shop would have done exactly what I wanted for a similar price, and I wouldnt have had to do all this chop cut rebuild. I honestly thought these would clamp on easy, which is why I bought them.
BlakeusMaximus
Still got to try a little lube on my speedo head
5 Year Member
Jul 12, 2017
2,477
1,348
173
May 1, 2018
#1,218
  • May 1, 2018
  • #1,218
I should check mine.
hoopty5.0
7,807
6,960
214
SW Houston
May 1, 2018
#1,219
  • May 1, 2018
  • #1,219
My shaft drips too, thought it was normal?
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
May 1, 2018
#1,220
  • May 1, 2018
  • #1,220
Lol, its starting to sound like it.
  • 59
  • 60
  • 61
  • 62
  • 63
  • 99
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
