Nick's "lvndpst" Restoration (and Slight Modification) Thread
  • Thread starter Thread starter 95BlueStallion
  • Start date Start date Nov 27, 2016
  • 92
  • 93
  • 94
  • 95
  • 96
  • 99
First Prev 94 of 99 Next Last
R
RichC93
Florida
Jul 26, 2020
#1,861
  • Jul 26, 2020
  • #1,861
95BlueStallion said:
They were def too tight, I already started resetting them yesterday. I ran out of time to get the job finished, but I can tell you what this noob did wrong.
I watched an internet vid of a guy who swore about his process he has used for 30 years, blah blah. I found zero lash, then tightened the nut. When you do it right, you can still barely spin the pushrods when the valve is closed. He had me cranking the engine around multiple times and retightening any that could still move. Basically I took him too literally, and made them too tight.
I will say this, my comp rockers have a lot of side to side play when they arent under load. I think I had them torqued correctly the first time, and the chatter I was hearing is just how they are. When they go under load as I rotate the engine around, they get tight and stay straight. When they are not under load, the pushrod is still snug, they can just slide back and forth side to side a bit on the fulcrum.
That guy was doing that with no oil in the lifters. That's the key to his method. I think he mentions that in the video.
95BlueStallion
My assy trans to myself
5,129
3,100
214
Cedar Rapids, Iowa
Mar 27, 2021
#1,862
  • Mar 27, 2021
  • #1,862
Well hello ladies and gents. Don’t get too excited, I don’t have any pictures. What I do have is a positive case of our favorite virus. I’m on day 7, and so far the body aches and congestion have only slightly improved. I’ve been isolated in one bedroom of our house, with my wife and son setting meals outside the door. I got so sick of being in one room day in and day out, that I broke out the Mustang for a short cruise. No stopping anywhere, just me and the road. After about 15 minutes, I couldn’t stand it anymore and went back home. This is really where things begin for me today.
My car has never had great drivability with the 347. The cam is aggressive, and was ground for a carb set up originally. I need a cam swap. With that being said, I will be upgrading my heads when I do this, as the current TFS 170s are small for my engine, and the cam needs to match what I choose. So then, while having this done, is there a solid argument to shell out for an aftermarket block? It will be staying N/A, but I would like it to be able to rev to 6,200-6,500.
I want to do this right the first time, and be done, but not waste money. I am hoping with the correct cam, heads, and my Systemax II intake that I will make 375-400 hp at the tire and similar torque. At this power level, in N/A form, do I need an aftermarket block to safely spin 6,200-6,500 RPM, or will a girdle and whatever other support be sufficient on my stock block?
@revhead347 , @TOOLOW91
Reactions: RaggedGT
Rdub6
So while I wait to figure out my rear end issues
5 Year Member
Dec 29, 2017
3,957
2,937
153
Long Island, NY
Mar 27, 2021
#1,863
  • Mar 27, 2021
  • #1,863
Get well soon man! Sounds like it didn’t get you too bad!
Im coming up on my year anniversary of having it, where my wife and daughter did the same for me as I was stuck in the den for 3 weeks! About drove me nuts!
Reactions: 95BlueStallion
Mustang5L5
Mod Dude
Feb 18, 2001
43,296
18,002
224
Massachusetts
Mar 27, 2021
#1,864
  • Mar 27, 2021
  • #1,864
Damn. Hope you feel better soon.
Can’t comment on the engine block myself as I’m still running the stock block myself. I guess I’ll just say that if this is your “final” combo, might make sense to invest the funds and build it on top of a good foundation?
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Mar 27, 2021
#1,865
  • Mar 27, 2021
  • #1,865
That’s my initial thinking as well, but I still have a transmission to buy, and it’s not a race car. Trying not to go overboard unless it’s truly needed.
Mustang5L5
Mod Dude
Feb 18, 2001
43,296
18,002
224
Massachusetts
Mar 27, 2021
#1,866
  • Mar 27, 2021
  • #1,866
If you aren’t planning on racing, why not just spec out a custom grind cam (or find a good aftermarket cam) swap it and get the driveability back? Do you want more power? (Stupid question)
General karthief
Mod Dude
Aug 25, 2016
28,002
10,632
213
polk county florida
Mar 27, 2021
#1,867
  • Mar 27, 2021
  • #1,867
Stick with the stock block, don't need no stink'n girdle for 6-6500 rpms, 400 hp.
JMO
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,946
5,818
213
Mar 27, 2021
#1,868
  • Mar 27, 2021
  • #1,868
High rpm and 500+ hp crack some stock blocks. There are people that have raced the stock blocks for years with more power and higher revving.
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Mar 27, 2021
#1,869
  • Mar 27, 2021
  • #1,869
My heads are holding the engine back. So my thought is to have a custom cam ground for a set of better heads. Then it’s matched, maximized, and done.
Reactions: Mustang5L5 and General karthief
General karthief
Mod Dude
Aug 25, 2016
28,002
10,632
213
polk county florida
Mar 27, 2021
#1,870
  • Mar 27, 2021
  • #1,870
It's a crap shoot, I like the stock block odds on the street, but what do I know.
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Mar 27, 2021
#1,871
  • Mar 27, 2021
  • #1,871
JMO
It already makes about 400 at the crank. I am talking 375-400 at the tires with bigger heads and a custom cam.
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Mar 27, 2021
#1,872
  • Mar 27, 2021
  • #1,872
Clear as mud, thanks man. Lol
General karthief
Mod Dude
Aug 25, 2016
28,002
10,632
213
polk county florida
Mar 27, 2021
#1,873
  • Mar 27, 2021
  • #1,873
As long as you don't rattle the engine showing off what's there to worry about?
Again what do I know.
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Mar 27, 2021
#1,874
  • Mar 27, 2021
  • #1,874
I haven’t yet figured out what you know...
Oh yeah, dump truck stuff.
Reactions: General karthief
General karthief
Mod Dude
Aug 25, 2016
28,002
10,632
213
polk county florida
Mar 27, 2021
#1,875
  • Mar 27, 2021
  • #1,875
Was that a dig?
Hey, dump trucks matter!!
RaggedGT
Mod Dude
Jul 20, 2014
4,750
3,206
203
Taylorsville ky
Mar 27, 2021
#1,876
  • Mar 27, 2021
  • #1,876
So if I’m reading this right, you’re gonna have some parts for sale in the near future?
Mustang5L5
Mod Dude
Feb 18, 2001
43,296
18,002
224
Massachusetts
Mar 27, 2021
#1,877
  • Mar 27, 2021
  • #1,877
I guess the way you sell it....I’d be leaning aftermarket block, cam and better heads too.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 28, 2021
#1,878
  • Mar 28, 2021
  • #1,878
We routinely run mid 5s on a 331 in the 1\8th.. car makes well over "block splitting" power...
Its all in the tuneup, don't rattle the engine and don't allow harmonics to damage the block.
We run IB rotating assembly only, lowers the stress on the block considerably.
95BlueStallion
5,129
3,100
214
Cedar Rapids, Iowa
Mar 28, 2021
#1,879
  • Mar 28, 2021
  • #1,879
Hmmm. I know mine is externally balanced. I was feeling pretty good until you said that part! I wish I wasn’t right in the block splitting level. With as little as I drive the car, I feel like I’d be fine with a good tune. However, that’s why I asked for the opinions of everyone. I guess I don’t dont have much to lose if I freshen up the stock block combo and it fails down the road. Swap it over now or wait and swap it when I’m forced to.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Mar 28, 2021
#1,880
  • Mar 28, 2021
  • #1,880
Lots of guys making big power. The killer is a bad tuneup.
  • 92
  • 93
  • 94
  • 95
  • 96
  • 99
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
