nitrous questions
  • Thread starter Thread starter Foxfan88
  • Start date Start date May 7, 2007
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
May 7, 2007
  • May 7, 2007
i have been freaking out on what to do next lately, SC, turbo, or nitrous.
just some questions i have on some nitrous stuff.
will a 190lph pump and19 lb injectors provide enough fuel for a dry 150 shot??i dont think it will but if not will the 190lph and 24lbers work?
also how do i fool the computer into dumping more fuel in using the dry kits?
will a 150 require a timing retard module? if i need one, how do these hook up exactly. or would it be better to manually retard timing when i am planning on spraying?
thanks for the help
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 7, 2007
  • May 7, 2007
I would think that a 150 shot would be pushing the 19lb injectors past there limit. Just get a wet kit. much safer. As for timing I like my Digital 6 MSD ignition box because it has a timing retard built into it. Otherwise for track use I would just retard my timing 6 degrees for the 150hp shot of juice. Also step sown 1 colder on plugs and gap them to .035.
stevesLX
373
cincinnati
May 8, 2007
  • May 8, 2007
Dont know what type of kit you plan on buying but I have a Zex dry dry kit that comes with a 75 100 and 125 shot and the nitrous management unit that the selinoid is built into has vacum lines that go to your AFPR and it adjusts your fuel pressure on its own depending on what fuel and nitrous jet you have installed. As far as timing goes it doesn't control any of that just how much fuel is added. I have a 255LPH and 24 LB injectors and I have my AFPR set at 32PSI and I dont need to make any adjustments other than my timing
88mouse
630
Mooresville nc
May 8, 2007
  • May 8, 2007
i would just get another selinoid and make your kit a wet kit that way you don't have to worry about it. 150 shot is to much for a dry kit.
D
Danman765432
471
Nutley, NJ
May 8, 2007
  • May 8, 2007
WIth the NOS dry kit, fuel pressure is bumped up through a vacuum tee that they make...when i spray my 80 shot it bumps my fuel pressure mid 60s psi
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
